Feature |
Product |
Release introduced |
Fabric Extend Integration with ExtremeCloud SD-WAN |
5320 Series |
Fabric Engine 8.10.1 Only 5320-48P-8XE and 5320-48T-8XE support more than one VRF with IP configuration. Beginning with Fabric Engine 9.0.3, you can specify the VRF that Auto-sense uses for SD-WAN on models that support a single active VRF. |
5420 Series |
Fabric Engine 8.10.1 |
5520 Series |
5720 Series |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.10.1 |
VSP 7400 Series |
VOSS 8.10.1 |
Auto-sense port Multi-area SPB support |
5320 Series |
Not Supported |
5420 Series |
Not Supported |
5520 Series |
Fabric Engine 9.0.3 |
5720 Series |
7520 Series |
7720 Series |
VSP 4900 Series |
Not Supported |
VSP 7400 Series |
VOSS 9.0.3 |
Note:
Requires a minimum of ExtremeCloud SD-WAN 24.4 |
5320 Series |
Fabric Engine 9.1 |
5420 Series |
Fabric Engine 9.1 |
5520 Series |
Fabric Engine 9.1 |
5720 Series |
Fabric Engine 9.1 |
7520 Series |
Fabric Engine 9.1 |
7720 Series |
Fabric Engine 9.1 |
VSP 4900 Series |
VOSS 9.1 |
VSP 7400 Series |
VOSS 9.1 |
Feature |
Product |
ExtremeCloud SD-WAN Local Breakout configuration applied through Auto-sense |
5320 Series |
Fabric Engine 9.1 Supported on 5320-48P-8XE and 5320-48T-8XE only |
5420 Series |
Fabric Engine 9.1 |
5520 Series |
Fabric Engine 9.1 |
5720 Series |
Fabric Engine 9.1 |
7520 Series |
Fabric Engine 9.1 |
7720 Series |
Fabric Engine 9.1 |
VSP 4900 Series |
VOSS 9.1 |
VSP 7400 Series |
VOSS 9.1 |
Feature |
Product |
Secondary IP Interfaces |
5320 Series |
Fabric Engine 8.10 Only 5320-48P-8XE and 5320-48T-8XE support more than one VRF with IP configuration. |
5420 Series |
Fabric Engine 8.10 |
5520 Series |
5720 Series |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.10 |
VSP 7400 Series |
VOSS 8.10 |
Feature |
Product |
Secure Boot For more information, see the Hardware Installation Guide for the supported product. |
5320 Series |
Not Supported |
5420 Series |
Supported |
5520 Series |
Supported |
5720 Series |
Supported |
7520 Series |
Supported |
7720 Series |
Supported |
VSP 4900 Series |
Not Supported |
VSP 7400 Series |
Not Supported |
Feature |
Product |
Secure Shell (SSH) server (IPv4) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Secure Shell (SSH) client (IPv4) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Secure Sockets Layer (SSL) certificate management |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
SSH server (IPv6) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
SSH client (IPv6) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
SSH client disable |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
SSH key sizes in multiples of 1024 |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
SSH rekey |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
Segmented Management Instance - Management Interface CLIP |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Segmented Management Instance - Management Interface OOB |
5320 Series |
Not Applicable |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.2 |
VSP 7400 Series |
VOSS 8.2 |
Segmented Management Instance - Management Interface VLAN |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Segmented Management Instance — ability to migrate VLAN or loopback IP address |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.2 |
VSP 7400 Series |
VOSS 8.2 |
Segmented Management Instance — DHCP Client for Management Interface OOB or Management Interface VLAN |
5320 Series |
Fabric Engine 8.6 OOB is not applicable. |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.2 |
VSP 7400 Series |
VOSS 8.2 |
Segmented Management Instance — sflow, Application Telemetry, and IPFIX |
5320 Series |
Fabric Engine 8.8 |
5420 Series |
Fabric Engine 8.8 |
5520 Series |
Fabric Engine 8.8 |
5720 Series |
Fabric Engine 8.8 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.8 |
VSP 7400 Series |
VOSS 8.8 |
Feature |
Product |
sFlow |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
sFlow — using Segmented Management Instance OOB interface as source IP |
5320 Series |
Not Supported |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.25 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.8 |
VSP 7400 Series |
VOSS 8.8 |
sFlow — using Segmented Management Instance VLAN interface as source IP |
5320 Series |
Fabric Engine 8.8 |
5420 Series |
Fabric Engine 8.8 |
5520 Series |
Fabric Engine 8.8 |
5720 Series |
Fabric Engine 8.8 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.8 |
VSP 7400 Series |
VOSS 8.8 |
sFlow — using Segmented Management Instance CLIP interface (GRT and VRFs) as source IP |
5320 Series |
Fabric Engine 8.8 |
5420 Series |
Fabric Engine 8.8 |
5520 Series |
Fabric Engine 8.8 |
5720 Series |
Fabric Engine 8.8 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.8 |
VSP 7400 Series |
VOSS 8.8 |
Feature |
Product |
Simple Loop Prevention Protocol (SLPP) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
Simple Network Management Protocol (SNMP) v1/2/3 (IPv4) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
SNMP (IPv6) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
SLPP Guard |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
SONMP |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
Spanning Tree Protocol (STP):
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
spbm-config-mode (boot config flags spbm-config-mode) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
SPB-PIM Gateway controller node |
5320 Series |
Not Supported |
5420 Series |
Not Supported |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Not Supported |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1.5 No supported on VSP4900-48P |
VSP 7400 Series |
VOSS 8.0 |
SPB-PIM Gateway interface |
5320 Series |
Not Supported |
5420 Series |
Not Supported |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Not Supported |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
Static routing |
5320 Series |
Fabric Engine 8.6 Only 5320-48P-8XE and 5320-48T-8XE support more than one VRF with IP configuration. |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
TACACS+ |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
TACACS+ secure communication using IPSec for IPv4 |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
Ability to adjust the maximum segment size (MSS) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.5 |
5520 Series |
VOSS 8.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.3.1 |
VSP 7400 Series |
VOSS 8.3.1 |
Feature |
Product |
Time Domain Reflectometer (Cable Diagnostic) |
5320 Series |
Fabric Engine 9.0.2 |
5420 Series |
Fabric Engine 8.10 Not supported on 5420F-24S-4XE |
5520 Series |
Fabric Engine 9.0.2 Not supported on 5520-24X or 5520-48SE |
5720 Series |
7520 Series |
Fabric Engine 9.0.2 Supported on 7520-48XT-6C |
7720 Series |
Not Supported |
VSP 4900 Series |
Not Supported |
VSP 7400 Series |
Not Supported |
Feature |
Product |
TLS server for secure HTTPS |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
Two-Factor Authentication for SSH |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Feature |
Product |
Unicast Reverse Path Forwarding (URPF) checking (IPv4) |
5320 Series |
Fabric Engine 8.6 Supported on 5320-48P-8XE and 5320-48T-8XE |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
Unicast Reverse Path Forwarding (URPF) checking (IPv6) |
5320 Series |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
